Salta al contenuto principale
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
Cosa ti serve
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, immagine 1 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, immagine 2 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, immagine 3 di 3
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, immagine 1 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, immagine 2 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, immagine 3 di 3
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 3, immagine 1 di 2 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 3, immagine 2 di 2
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, immagine 1 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, immagine 2 di 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, immagine 3 di 3
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
Conclusione
3 Commenti
Where can I get the seals?
Ahmed - Replica
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - Replica
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,057
