Salta al contenuto principale
Olympus Stylus Tough 6020 Shutter Button Replacement
Cosa ti serve
  1. Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: passo 1, immagine 1 di 3 Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: passo 1, immagine 2 di 3 Olympus Stylus Tough 6020 Shutter Button Replacement, Shutter Button: passo 1, immagine 3 di 3
    • Turn the camera so that you are looking at the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
    • Using your fingers, pull off the shutter button.
    • You may need to use a spudger to pry off the shutter button.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 404
