Salta al contenuto principale
Olympus Stylus 760 LCD Screen Replacement
Cosa ti serve
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: passo 1, immagine 1 di 1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: passo 2, immagine 1 di 1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: passo 3, immagine 1 di 1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: passo 7, immagine 1 di 3 Olympus Stylus 760 LCD Screen Replacement: passo 7, immagine 2 di 3 Olympus Stylus 760 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: passo 8, immagine 1 di 2 Olympus Stylus 760 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: passo 9, immagine 1 di 3 Olympus Stylus 760 LCD Screen Replacement: passo 9, immagine 2 di 3 Olympus Stylus 760 LCD Screen Replacement: passo 9, immagine 3 di 3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: passo 10, immagine 1 di 1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: passo 11, immagine 1 di 2 Olympus Stylus 760 LCD Screen Replacement: passo 11, immagine 2 di 2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: passo 12, immagine 1 di 2 Olympus Stylus 760 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: passo 13, immagine 1 di 1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
Conclusione
Un commento
from where i can get repaired u760 camera
tahir zafar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,508
