Salta al contenuto principale
Olympus Stylus 1010 LCD Display Replacement
Cosa ti serve
  1. Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, immagine 1 di 2 Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, immagine 2 di 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 LCD Display Replacement: passo 2, immagine 1 di 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 LCD Display Replacement: passo 3, immagine 1 di 2 Olympus Stylus 1010 LCD Display Replacement: passo 3, immagine 2 di 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 LCD Display Replacement: passo 4, immagine 1 di 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 LCD Display Replacement: passo 5, immagine 1 di 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 LCD Display Replacement: passo 6, immagine 1 di 3 Olympus Stylus 1010 LCD Display Replacement: passo 6, immagine 2 di 3 Olympus Stylus 1010 LCD Display Replacement: passo 6, immagine 3 di 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the caseā€”one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 LCD Display Replacement: passo 7, immagine 1 di 3 Olympus Stylus 1010 LCD Display Replacement: passo 7, immagine 2 di 3 Olympus Stylus 1010 LCD Display Replacement: passo 7, immagine 3 di 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 LCD Display Replacement, LCD Display: passo 8, immagine 1 di 1
    • Peel up the blue and black tape. This can be done with a spudger.
  9. Olympus Stylus 1010 LCD Display Replacement: passo 9, immagine 1 di 2 Olympus Stylus 1010 LCD Display Replacement: passo 9, immagine 2 di 2
    • Unscrew the screws. (6 screws)( photo shows 7 screws -editorial comment)
  10. Olympus Stylus 1010 LCD Display Replacement: passo 10, immagine 1 di 2 Olympus Stylus 1010 LCD Display Replacement: passo 10, immagine 2 di 2
    • Push out the LCD screen by pushing on the screen side.
Conclusione
Altre 2 persone hanno completato questa guida.
Curtis Reedy
Membro da: 01/12/11
267 Reputazione
2 Guide realizzate
Cal Poly, Team 13-4, Forte Winter 2011 Membro di Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 4,547
