Salta al contenuto principale
Olympus SZ-12 Lens Replacement
Cosa ti serve
  1. Olympus SZ-12 Lens Replacement, Back Case: passo 1, immagine 1 di 2 Olympus SZ-12 Lens Replacement, Back Case: passo 1, immagine 2 di 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 Lens Replacement: passo 2, immagine 1 di 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 Lens Replacement: passo 3, immagine 1 di 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 Lens Replacement: passo 4, immagine 1 di 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 Lens Replacement: passo 5, immagine 1 di 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 Lens Replacement: passo 6, immagine 1 di 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 Lens Replacement, LCD Screen: passo 7, immagine 1 di 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 Lens Replacement: passo 8, immagine 1 di 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 Lens Replacement: passo 9, immagine 1 di 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
  10. Olympus SZ-12 Lens Replacement, Lens: passo 10, immagine 1 di 2 Olympus SZ-12 Lens Replacement, Lens: passo 10, immagine 2 di 2
    • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
  11. Olympus SZ-12 Lens Replacement: passo 11, immagine 1 di 3 Olympus SZ-12 Lens Replacement: passo 11, immagine 2 di 3 Olympus SZ-12 Lens Replacement: passo 11, immagine 3 di 3
    • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
  12. Olympus SZ-12 Lens Replacement: passo 12, immagine 1 di 3 Olympus SZ-12 Lens Replacement: passo 12, immagine 2 di 3 Olympus SZ-12 Lens Replacement: passo 12, immagine 3 di 3
    • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
  13. Olympus SZ-12 Lens Replacement: passo 13, immagine 1 di 1
    • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
    • Remove the lens frame.
  14. Olympus SZ-12 Lens Replacement: passo 14, immagine 1 di 3 Olympus SZ-12 Lens Replacement: passo 14, immagine 2 di 3 Olympus SZ-12 Lens Replacement: passo 14, immagine 3 di 3
    • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
    • Remove the lens.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,637
