Salta al contenuto principale
Olympus SZ-12 LCD Screen Replacement
Cosa ti serve
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: passo 1, immagine 1 di 2 Olympus SZ-12 LCD Screen Replacement, Back Case: passo 1, immagine 2 di 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: passo 2, immagine 1 di 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: passo 3, immagine 1 di 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: passo 4, immagine 1 di 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: passo 5, immagine 1 di 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 800
