Salta al contenuto principale
Olympus SP-320 Back casing and LCD screen Replacement
Cosa ti serve
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, immagine 3 di 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: passo 2, immagine 1 di 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: passo 3, immagine 1 di 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, immagine 3 di 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 1 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 2 di 3 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, immagine 3 di 3
    • You have detached the back casing and LCD screen.
Conclusione
1Commento della guida
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 789
