Salta al contenuto principale
Olympus Pen E-PL7 Back Case Replacement
Cosa ti serve
  1. Olympus Pen E-PL7 Back Case Replacement, Back Case: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  2. Olympus Pen E-PL7 Back Case Replacement: passo 2, immagine 1 di 1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  3. Olympus Pen E-PL7 Back Case Replacement: passo 3, immagine 1 di 1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  4. Olympus Pen E-PL7 Back Case Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  5. Olympus Pen E-PL7 Back Case Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  6. Olympus Pen E-PL7 Back Case Replacement: passo 6, immagine 1 di 1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  7. Olympus Pen E-PL7 Back Case Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  8. Olympus Pen E-PL7 Back Case Replacement: passo 8, immagine 1 di 1
    • Remove the lens mount with tweezers.
  9. Olympus Pen E-PL7 Back Case Replacement: passo 9, immagine 1 di 1
    • Use tweezers to remove the inner metal ring.
  10. Olympus Pen E-PL7 Back Case Replacement: passo 10, immagine 1 di 2 Olympus Pen E-PL7 Back Case Replacement: passo 10, immagine 2 di 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  11. Olympus Pen E-PL7 Back Case Replacement: passo 11, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  12. Olympus Pen E-PL7 Back Case Replacement: passo 12, immagine 1 di 1
    • Remove the two 4 mm Phillips screws.
  13. Olympus Pen E-PL7 Back Case Replacement: passo 13, immagine 1 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 13, immagine 2 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 13, immagine 3 di 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  14. Olympus Pen E-PL7 Back Case Replacement: passo 14, immagine 1 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 14, immagine 2 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 14, immagine 3 di 3
    • Use tweezers to remove the metal clip from the external flash mount.
  15. Olympus Pen E-PL7 Back Case Replacement: passo 15, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  16. Olympus Pen E-PL7 Back Case Replacement: passo 16, immagine 1 di 2 Olympus Pen E-PL7 Back Case Replacement: passo 16, immagine 2 di 2
    • Remove the second external flash clip with tweezers.
  17. Olympus Pen E-PL7 Back Case Replacement: passo 17, immagine 1 di 2 Olympus Pen E-PL7 Back Case Replacement: passo 17, immagine 2 di 2
    • Remove the external flash port casing to expose five more screws.
  18. Olympus Pen E-PL7 Back Case Replacement: passo 18, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  19. Olympus Pen E-PL7 Back Case Replacement: passo 19, immagine 1 di 1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  20. Olympus Pen E-PL7 Back Case Replacement: passo 20, immagine 1 di 1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  21. Olympus Pen E-PL7 Back Case Replacement: passo 21, immagine 1 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 21, immagine 2 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 21, immagine 3 di 3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  22. Olympus Pen E-PL7 Back Case Replacement: passo 22, immagine 1 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 22, immagine 2 di 3 Olympus Pen E-PL7 Back Case Replacement: passo 22, immagine 3 di 3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
Conclusione
Altre 3 persone hanno completato questa guida.
Kelsea Weber
Membro da: 11/12/15
19.864 Reputazione
32 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
Un commento
Loads of screws that don’t need to be removed just to remove the rear case.
Omit step 3,
Omit steps 6 to 13
Omit step 18
Take great care not to pull on ribbon cables
Rod Heeley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,226
