Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
The SD Card Door allows access to both the camera's SD Card and the battery. In order to keep the battery and SD card protected from outside damage, the SD Card Door needs to be intact. If the SD Card Door has been damaged, you can use this guide to ensure you are properly removing and replacing it.
  1. Open battery/SD card door latch by moving the black button in the direction of the arrow, towards the camera screen.
    • Open battery/SD card door latch by moving the black button in the direction of the arrow, towards the camera screen.
  2. Grab the SD card door and remove it by pulling it away from the body of the camera. Grab the SD card door and remove it by pulling it away from the body of the camera.
    • Grab the SD card door and remove it by pulling it away from the body of the camera.
Conclusione
To reassemble a new SD card door to your device, follow these instructions in reverse order.
Nicolle Oliver
Membro da: 14/02/2018
115 Reputazione
1 Guida realizzata
USF Tampa, Team S5-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 59
Tutti i Tempi: 444
