Salta al contenuto principale
Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement
Cosa ti serve
  1. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement, HDMI and Multi-connector Cover: passo 1, immagine 1 di 1
    • There are three different types and lengths of screws used to hold the bottom plate of the camera. Make proper note of each screws original position during your disassembly.
    • Using the PH00 Phillips-head screwdriver, unscrew the two 1/3 inch screws with silver threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/3 inch screws with blue threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/2 inch screws with silver threads from the the bottom of the camera.
  2. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: passo 2, immagine 1 di 1
    • After removing all of the screws, remove the bottom plate from the camera to continue.
  3. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: passo 3, immagine 1 di 2 Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: passo 3, immagine 2 di 2
    • Continuing to use the size PH00 Phillips-head screwdriver, remove the two 3/5 inch screws revealed after removing the bottom plate of the camera.
  4. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: passo 4, immagine 1 di 1
    • Open the HDMI connector door and continue to use the PH00 Phillips-head screwdriver to remove the 3/10 inch screw located underneath the door.
  5. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: passo 5, immagine 1 di 1
    • Proper removal of all 11 screws listed in the steps above from the camera gives the camera the ability to be opened slightly and allows for the door to be lifted off of the hooks holding it in place within the camera.
Conclusione
To add your new HDMI connector door, follow these instructions in reverse order.
Allen Anjal
Membro da: 09/27/16
320 Reputazione
2 Guide realizzate
USF Tampa, Team S5-G6, Eyestone Spring 2018 Membro di USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
4 Membri
10 Guide realizzate
Un commento
so, where can I buy the port cover or door for the OMD-em10 mark2? Thanks
Raffy Martinez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,778
