Salta al contenuto principale
Olympus FE-210 Lens Assembly Replacement
Cosa ti serve
  1. Olympus FE-210 Lens Assembly Replacement, Battery: passo 1, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Olympus FE-210 Lens Assembly Replacement: passo 2, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement: passo 2, immagine 2 di 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: passo 3, immagine 1 di 3 Olympus FE-210 Lens Assembly Replacement, Front Casing: passo 3, immagine 2 di 3 Olympus FE-210 Lens Assembly Replacement, Front Casing: passo 3, immagine 3 di 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Olympus FE-210 Lens Assembly Replacement: passo 4, immagine 1 di 3 Olympus FE-210 Lens Assembly Replacement: passo 4, immagine 2 di 3 Olympus FE-210 Lens Assembly Replacement: passo 4, immagine 3 di 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: passo 5, immagine 1 di 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Olympus FE-210 Lens Assembly Replacement: passo 6, immagine 1 di 3 Olympus FE-210 Lens Assembly Replacement: passo 6, immagine 2 di 3 Olympus FE-210 Lens Assembly Replacement: passo 6, immagine 3 di 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: passo 7, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  8. Olympus FE-210 Lens Assembly Replacement: passo 8, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement: passo 8, immagine 2 di 2
    • Remove the seven 2.7 mm using a #00 screwdriver.
  9. Olympus FE-210 Lens Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  10. Olympus FE-210 Lens Assembly Replacement: passo 10, immagine 1 di 1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  11. Olympus FE-210 Lens Assembly Replacement: passo 11, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement: passo 11, immagine 2 di 2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  12. Olympus FE-210 Lens Assembly Replacement: passo 12, immagine 1 di 1
    • Remove the motherboard from the camera casing.
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: passo 13, immagine 1 di 1
    • Remove the three 3.6 mm screws using a #00 screwdriver.
  14. Olympus FE-210 Lens Assembly Replacement: passo 14, immagine 1 di 2 Olympus FE-210 Lens Assembly Replacement: passo 14, immagine 2 di 2
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
Conclusione
Matt
Membro da: 01/25/11
811 Reputazione
6 Guide realizzate
Cal Poly, Team 4-36, Regan Winter 2011 Membro di Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Membri
14 Guide realizzate
Un commento
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,198
