Salta al contenuto principale
Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement
Cosa ti serve
  1. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Front Case: passo 1, immagine 1 di 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 2, immagine 1 di 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 3, immagine 1 di 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 4, immagine 1 di 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 5, immagine 1 di 1
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Shutter + ON/OFF Buttons Plastic Holder: passo 6, immagine 1 di 1
    • Use the PH000 to remove the 7mm screw on the upper right corner of the device.
  7. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 7, immagine 1 di 1
    • Use the PH000 screwdriver to remove the 5 mm screw located on the top left side of the device.
  8. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 8, immagine 1 di 1
    • Use the PH000 screwdriver to remove the 3mm screw shown on the picture.
  9. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 9, immagine 1 di 1
    • Using the PH000, remove the 3mm screw shown on the picture.
  10. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 10, immagine 1 di 1
    • Use the PH000 screwdriver to remove the 4mm located below the ON/OFF button.
  11. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: passo 11, immagine 1 di 1
    • Using your hand, remove the plastic button holder containing the shutter and ON/OFF buttons. The buttons and metal springs under it are now unlocked.
Conclusione
USF Tampa, Team 1-6, Leahy Fall 2016 Membro di USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Membri
10 Guide realizzate
Un commento
Thanks for the post. Do you know where to buy new switches?
Richard Chesher - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,676
