Introduzione
This Guide will give step-by-step instructions on how to install a microphone and speaker system into the Olympus D590 camera.
Flip camera so you are looking at the bottom.
  • Flip camera so you are looking at the bottom.
  • Unscrew all 5 base plate screws.
Aggiungi Commento
Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
Aggiungi Commento
  • Unscrew the single screw located next to the battery slot.
Aggiungi Commento
  • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
  • Lift the rubber plate exposing the ports beneath.
Aggiungi Commento
  • Unscrew the 2 screws next to the USB and AC ports.
Aggiungi Commento
  • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
Aggiungi Commento
  • Pull off the faceplate to reveal the inside of the camera.
  • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
Aggiungi Commento
  • Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
Aggiungi Commento
  • Unscrew the 2 screws located on either side of the flash.
Aggiungi Commento
  • Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
  • Carefully pry off the blackplate from the remaining part of the camera.
Aggiungi Commento
  • Pull the backplate off.
Aggiungi Commento
  • Unscrew the screw shown in the picture from LCD screen.
Aggiungi Commento
  • Remove the side pannel by sliding it off the body of the camera.
  • Lift the camera no more than 3cm to make sure all screws have been taken off.
Aggiungi Commento
  • Flip camera so you are looking at the front.
  • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
  • Be careful not to rip the wiring tape with the tweezers.
Aggiungi Commento
  • Locate the tape securing the wiring with the gray end piece located on top of the camera.
  • Gently lift up on the tape till all wires are exposed.
Aggiungi Commento
  • Flip Camera to the bottom side as shown.
  • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
Aggiungi Commento
  • Flip camera so the front is facing you.
  • Locate speaker in upper right hand corner.
  • Gently lift with tweasers.
  • Feed wiring through designated spot so that it is no longer connected to the camera.
Aggiungi Commento
  • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
  • Gently pull the thick yellow wiring out by using the forefinger and thumb.
Aggiungi Commento
  • Locate speaker on the back of the LCD screen.
  • Remove the tape holding the speaker down by lifing with tweesers.
  • Remove speaker from holding dock.
Aggiungi Commento
Conclusione
Joshua
Membro da: 15/04/2010
7 Reputazione
2 Guide realizzate
Cal Poly, Team 28-23, Regan Spring 2010 Membro di Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,326
