Salta al contenuto principale
Olympus 850SW Memory Card Replacement
  1. Olympus 850SW Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
    • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
    • Make sure to remove the battery before trying to remove the memory card.
  2. Olympus 850SW Memory Card Replacement: passo 2, immagine 1 di 1
    • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
  3. Olympus 850SW Memory Card Replacement: passo 3, immagine 1 di 1
    • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
    • Insert the card into the compartment fully until it clicks into place.
  4. Olympus 850SW Memory Card Replacement: passo 4, immagine 1 di 1
    • Close the memory card latch/ battery latch.
Conclusione
Un commento
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,666
