Introduzione
The X7R Marauder from Olight is a great flashlight. Unfortunately, the batteries are permanently installed and, according to the manufacturer, cannot be replaced by the user.
If your batteries go bad after the warranty has expired, you can use the following steps to replace the batteries in your Olight 7XR flashlight.
Cosa ti serve
The three screws on the side can be loosened by a 0.9mm Allen key.
The cover can then be removed.
Reverse the steps to reassemble your device.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Andrew S ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
what size allen key?
what size are the batteries?
The allen key size is H0.9mm
The battery size is 18650.
Andrew S -
