Salta al contenuto principale
Oil Change
Cosa ti serve
  1. Oil Change, Oil Change: passo 1, immagine 1 di 3 Oil Change, Oil Change: passo 1, immagine 2 di 3 Oil Change, Oil Change: passo 1, immagine 3 di 3
    • Make sure the engine is cool before completing the Oil Change.
    • Rotate Dipstick Cap counterclockwise until completely unthreaded.
    • The Dipstick Cap is generally yellow or orange.
  2. Oil Change: passo 2, immagine 1 di 2 Oil Change: passo 2, immagine 2 di 2
    • Place your Drain Pan below the engine and flip the engine over so that the used oil pours out of the Dipstick spout.
    • Set the engine back down and fill the engine with the new oil until it reaches the designated fill line.
Conclusione
To reassemble your device, follow Step 1 and 2 in reverse order.
Jack Linchey
Membro da: 04/19/18
277 Reputazione
2 Guide realizzate
Cal Poly, Team S25-G15, Maness Spring 2018 Membro di Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 437
