Salta al contenuto principale
Oculus Touch Controllers (2nd generation) Battery Replacement
Cosa ti serve
  1. Oculus Touch Controllers (2nd generation) Battery Replacement, Opening: passo 1, immagine 1 di 1
    • Slide down the cover on the left or right side of your chosen controller.
  2. Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: passo 2, immagine 1 di 3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: passo 2, immagine 2 di 3 Oculus Touch Controllers (2nd generation) Battery Replacement, Taking out the battery: passo 2, immagine 3 di 3
    • After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
    • You can also use the top of the cover to push and lift the battery if you don't have an opening tool.
    • Recycle batteries properly.
Conclusione
Artem Ivat
Membro da: 02/05/20
3.546 Reputazione
13 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,967
