Introduzione
If the device is not working properly this could be due to a broken headset motherboard. Common causes for motherboard failures include being exposed to static shock, overheating, or component failure.
Cosa ti serve
Remove front cover plate.
Unplug the USB and HDMI cables from the Oculus Rift DK2.
With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
Altre 7 persone hanno completato questa guida.
