Salta al contenuto principale
Oculus Rift DK1 Control Box Buttons Replacement
Cosa ti serve
  1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: passo 1, immagine 1 di 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: passo 1, immagine 2 di 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: passo 1, immagine 3 di 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift DK1 Control Box Buttons Replacement: passo 2, immagine 1 di 3 Oculus Rift DK1 Control Box Buttons Replacement: passo 2, immagine 2 di 3 Oculus Rift DK1 Control Box Buttons Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: passo 3, immagine 1 di 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: passo 3, immagine 2 di 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: passo 3, immagine 3 di 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift DK1 Control Box Buttons Replacement: passo 4, immagine 1 di 3 Oculus Rift DK1 Control Box Buttons Replacement: passo 4, immagine 2 di 3 Oculus Rift DK1 Control Box Buttons Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
  5. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: passo 5, immagine 1 di 1
    • You now have the motherboard separated from the control box.
    • Identify the buttons that are not working.
  6. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: passo 6, immagine 1 di 1
    • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
    • Be careful! Soldering iron is hot.
  7. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: passo 7, immagine 1 di 2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
    • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
Conclusione
Ross De Vito
Membro da: 01/13/15
246 Reputazione
2 Guide realizzate
Cal Poly, Team 70-5, Forte Winter 2015 Membro di Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 742
