Salta al contenuto principale
ORFELD EV-660-S222 Battery LED Board Replacement
Cosa ti serve
  1. ORFELD EV-660-S222 Battery LED Board Replacement, Battery LED Board: passo 1, immagine 1 di 1
    • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
  2. ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, immagine 1 di 2 ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, immagine 2 di 2
    • Place the vacuum on its side, with the screws facing towards you.
    • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
  3. ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, immagine 1 di 2 ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, remove the sticker connecting the two halves.
    • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
    • Press the blue buttons near the sides of the battery LEDs to remove the top half.
  4. ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, immagine 1 di 2 ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, immagine 2 di 2
    • Slide out the charging port.
  5. ORFELD EV-660-S222 Battery LED Board Replacement: passo 5, immagine 1 di 1
    • Lift the battery slightly to reveal the pin connectors.
    • Gently disconnect the six-pin connector that connects to the power button and battery LEDs.
  6. ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, immagine 1 di 3 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, immagine 2 di 3 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, immagine 3 di 3
    • Slide out the battery LEDs from the compartment.
    • Remove the plastic LED cover from the LED board.
  7. ORFELD EV-660-S222 Battery LED Board Replacement: passo 7, immagine 1 di 1
    • Desolder the LED board from the wires.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 806
