Salta al contenuto principale
OLPC XO-4 Touch Keyboard Replacement
Cosa ti serve
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the laptop upside-down, with the handle facing away from you.
    Chiedi a FixBot
    Aggiungi Commento
  2. OLPC XO-4 Touch Keyboard Replacement: passo 2, immagine 1 di 2 OLPC XO-4 Touch Keyboard Replacement: passo 2, immagine 2 di 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    Chiedi a FixBot
    Aggiungi Commento
  3. OLPC XO-4 Touch Keyboard Replacement: passo 3, immagine 1 di 2 OLPC XO-4 Touch Keyboard Replacement: passo 3, immagine 2 di 2
    • Lift up on the middle of the battery to remove it from the device.
    Chiedi a FixBot
    Aggiungi Commento
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: passo 4, immagine 1 di 2 OLPC XO-4 Touch Keyboard Replacement, Keyboard: passo 4, immagine 2 di 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
    Chiedi a FixBot
    Aggiungi Commento
  5. OLPC XO-4 Touch Keyboard Replacement: passo 5, immagine 1 di 3 OLPC XO-4 Touch Keyboard Replacement: passo 5, immagine 2 di 3 OLPC XO-4 Touch Keyboard Replacement: passo 5, immagine 3 di 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  6. OLPC XO-4 Touch Keyboard Replacement: passo 6, immagine 1 di 2 OLPC XO-4 Touch Keyboard Replacement: passo 6, immagine 2 di 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. OLPC XO-4 Touch Keyboard Replacement: passo 7, immagine 1 di 2 OLPC XO-4 Touch Keyboard Replacement: passo 7, immagine 2 di 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 3-30, Amido Winter 2013 Membro di Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 35
Tutti i Tempi: 1,349
