Salta al contenuto principale
Nvidia Shield Tablet Touchscreen Controller Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: passo 1, immagine 1 di 2 Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: passo 1, immagine 2 di 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, immagine 1 di 3 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, immagine 2 di 3 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 3, immagine 1 di 2 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 3, immagine 2 di 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: passo 4, immagine 1 di 2 Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: passo 4, immagine 2 di 2
    $7.95
    Compra
    • Peel away the tape covering the top right side of the motherboard. The plastic opening tools are useful in nudging the tape off.
    • Make sure you are using your anti-static wrist strap.
  5. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 5, immagine 1 di 2 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 5, immagine 2 di 2
    • Using the precision tweezers, gently remove the touchscreen controller from its port.
Conclusione
Molly Bauer
Membro da: 08/27/15
1.424 Reputazione
6 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro di USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membri
11 Guide realizzate
4 Commenti
how to change this controller ???? he is not removable !!! where to buy it?
Tom - Replica
How are you supposed to replace this part if it's connected to the Touchscreen panel by a flat ribbon cable. The pictures show the touchscreen controller that has been severed/cut by where the flat cable goes 90 degrees towards the touchscreen, you cannot just replace this part by itself as shown in the pictures. WTF????
Luis Nido - Replica
My Thoughts exactly. Mine has one connector that is easily removed, the smaller end. The large wide end is up under a metal frame. I gave a gentle tug, but apparently its glued or sealed. Now to figure out how to remove it. Guessing a heat gun to the glass is the easiest way? No coming apart from the back/inside!
The Watson - Replica
why is this still up. you can’t replace this part so the title is misleading. This part is torn easy you must remove the board from the tablet with the touch cable connector unlatched but the cable still in. if you try to bull it out first it rips.
MYdeviceRepair - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,148
