Salta al contenuto principale
Nvidia Shield Tablet Speaker Replacement
Cosa ti serve
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: passo 1, immagine 1 di 2 Nvidia Shield Tablet Speaker Replacement, Rear Case: passo 1, immagine 2 di 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: passo 2, immagine 1 di 3 Nvidia Shield Tablet Speaker Replacement: passo 2, immagine 2 di 3 Nvidia Shield Tablet Speaker Replacement: passo 2, immagine 3 di 3
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: passo 3, immagine 1 di 2 Nvidia Shield Tablet Speaker Replacement: passo 3, immagine 2 di 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: passo 4, immagine 1 di 1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: passo 6, immagine 1 di 3 Nvidia Shield Tablet Speaker Replacement: passo 6, immagine 2 di 3 Nvidia Shield Tablet Speaker Replacement: passo 6, immagine 3 di 3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: passo 7, immagine 1 di 2 Nvidia Shield Tablet Speaker Replacement: passo 7, immagine 2 di 2
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
Conclusione
Molly Bauer
Membro da: 08/27/15
1.424 Reputazione
6 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro di USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membri
11 Guide realizzate
Un commento
This didn't work
Riley Schork - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,585
