Salta al contenuto principale
Nvidia Shield Tablet Rear Case Replacement
Cosa ti serve
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: passo 1, immagine 1 di 2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: passo 1, immagine 2 di 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 1 di 3 Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 2 di 3 Nvidia Shield Tablet Rear Case Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: passo 3, immagine 1 di 2 Nvidia Shield Tablet Rear Case Replacement: passo 3, immagine 2 di 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
Conclusione
Altre 5 persone hanno completato questa guida.
Molly Bauer
Membro da: 08/27/15
1.424 Reputazione
6 Guide realizzate
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro di USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membri
11 Guide realizzate
Un commento
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,299
