Salta al contenuto principale
Nvidia Shield TV 1st Generation I/O Board Replacement
Cosa ti serve
  1. Nvidia Shield TV 1st Generation I/O Board Replacement, I/O Board: passo 1, immagine 1 di 1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 2, immagine 1 di 2 Nvidia Shield TV 1st Generation I/O Board Replacement: passo 2, immagine 2 di 2
    • Remove the indicated cables and ribbon wires.
  3. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 3, immagine 1 di 2 Nvidia Shield TV 1st Generation I/O Board Replacement: passo 3, immagine 2 di 2
    • Remove the indicated four screws using the T6 Torx screwdriver.
  4. Nvidia Shield TV 1st Generation I/O Board Replacement: passo 4, immagine 1 di 1
    • Carefully tilt and pull out the I/O board from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Membri
7 Guide realizzate
4 Commenti
where do i get a new I/O Board ?
Max Eschbach (SAVAGE) - Replica
Yaaa, where can we get the I/O board? :-D
VashCZ - Replica
Yes, i need a replacement I/O board too, where can I find one?
Anand Dhungav - Replica
Where can I get a replacement I/O board? What good are instructions without any availability for parts?
Mike - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,928
