Salta al contenuto principale
Nvidia Shield TV 1st Generation Controller Battery Replacement
Cosa ti serve
  1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, immagine 2 di 2
    • Remove the indicated six screws using the T6 Torx screwdriver.
  2. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to pry the face of the controller away from the body.
    • Make sure the controller is face down during this step as the buttons can easily fall out.
  3. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 3, immagine 1 di 1
    • Carefully remove the indicated ribbon wires from the face of the controller.
  4. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, immagine 1 di 2 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
    • Lift the vibration motor out of the front case.
    • Repeat for the other side.
    • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
  5. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 1 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 2 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, immagine 3 di 3
    • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
    • Lift the logic board away from the front case.
  6. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 1 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 2 di 3 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, immagine 3 di 3
    • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
    • Remove the panel from the front case.
    • Lift the battery from the front case to remove it.
Conclusione
Altre 12 persone hanno completato questa guida.
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Membri
7 Guide realizzate
8 Commenti
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Replica
LC18650 Remote Control accu
djcornelissen - Replica
Are battery packs available for the 2017 controller?
Andrew - Replica
Simply reconnecting the battery fixed my issues
Charles Keisler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 67
Tutti i Tempi: 19,727
