Salta al contenuto principale
Nvidia Shield Pro Android TV Hard Drive Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: passo 1, immagine 1 di 2 Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV Hard Drive Replacement: passo 3, immagine 1 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement: passo 3, immagine 2 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement: passo 3, immagine 3 di 3
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV Hard Drive Replacement: passo 4, immagine 1 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement: passo 4, immagine 2 di 3 Nvidia Shield Pro Android TV Hard Drive Replacement: passo 4, immagine 3 di 3
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
  5. Nvidia Shield Pro Android TV Hard Drive Replacement: passo 5, immagine 1 di 2 Nvidia Shield Pro Android TV Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV Hard Drive Replacement: passo 6, immagine 1 di 1
    • Gently pull the hard drive out of the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Jimmy Chen
Membro da: 01/23/20
717 Reputazione
3 Guide realizzate
Cal Poly, Team S18-G2, White Winter 2020 Membro di Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membri
14 Guide realizzate
5Commenti sulla guida
The problem with this, is after replacing the Malfunctioning or Corrupted drive that will not solve the problem.
The device still will not run if there’s no Software or Firmware installed onto the new drive.
Can iFixit include that procedure of getting the new drive running.
Because you cannot clone a corrupt or bad drive .
Dennis Teague - Replica
You took the words right out of my mouth. I have read the Nvidia website on how to do this but some of it is over my head. We need a flash for dummies to make sure we do it correctly!
Larry -
ok and now what??? nothing happens… there is no image on the new disk… how do i get it to boot? just stays on green light with no image on screen no boot
John Feathers - Replica
I agree with John, please describe how to flash the image on the new drive.
Mario Martinez - Replica
Hello everyone,
Since its an android device, steps are similar in flashing an android phone.
I found this, hope it helps!
steps:
https://developer.download.nvidia.com/as...
images:
https://developer.nvidia.com/shield-deve...
ContactLeft - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 156
Tutti i Tempi: 8,135
