Salta al contenuto principale
Nvidia Shield Pro Android TV Fan/Heat Sink Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: passo 1, immagine 1 di 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: passo 2, immagine 1 di 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: passo 2, immagine 2 di 3 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement, Fan/Heat Sink: passo 2, immagine 3 di 3
    • Remove the five screws with a T6 Torx screwdriver.
    • Two of the screws are located directly on top of the fan/heat sink. The other three screws are located on a small triangle plate on the left side of the fan/heat sink.
  3. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: passo 3, immagine 1 di 2 Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: passo 3, immagine 2 di 2
    • Once the screws are removed, gently detach the multi-colored wired connection from the motherboard.
  4. Nvidia Shield Pro Android TV Fan/Heat Sink Replacement: passo 4, immagine 1 di 1
    • Gently remove the fan/heat sink out of the Nvidia Shield.
Conclusione
Altre 2 persone hanno completato questa guida.
Jimmy Chen
Membro da: 01/23/20
615 Reputazione
3 Guide realizzate
Cal Poly, Team S18-G2, White Winter 2020 Membro di Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membri
6 Guide realizzate
2 Commenti
Hello can you tell me where to buy the fan and the plastic case opener?
Sajid Idrees - Replica
My version had screws in the back which I had to remove, and then I could simply slide it away from the ports in the back to open it. The inside was completely different as well, but it's a pretty simple device.
John Doe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 181
Tutti i Tempi: 8,671
