Salta al contenuto principale
Nvidia Shield Pro Android TV Controller Triggers Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: passo 1, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: passo 1, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: passo 1, immagine 3 di 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 2, immagine 1 di 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 3, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 3, immagine 2 di 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 4, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 4, immagine 2 di 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 5, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 5, immagine 2 di 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: passo 6, immagine 3 di 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: passo 7, immagine 3 di 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
Conclusione
1Commento della guida
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 519
