Salta al contenuto principale
Nvidia Shield Pro Android TV Controller Thumbsticks Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: passo 1, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: passo 1, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Thumbsticks: passo 1, immagine 3 di 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 2, immagine 1 di 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 3, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 3, immagine 2 di 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 4, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 4, immagine 2 di 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 5, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: passo 5, immagine 2 di 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
Conclusione
Altre 3 persone hanno completato questa guida.
Ben Carrasco
Membro da: 01/23/20
347 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G2, White Winter 2020 Membro di Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membri
14 Guide realizzate
3Commenti sulla guida
Very good instructions that were very helpful. Do you have recommendations on which thumbsticks are the best since the shield seems to have wider and deeper ones? Thanks again for the guide.
Charles Brodie - Replica
Just wondering where would I be able to buy a thumbstick spare part to replace it.
xguyun - Replica
Thanks, very good post, and it could be very useful for me. Just wondering where would I be able to buy a spare part for this thumbstick to replace my broken one.
xguyun - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,294
