Salta al contenuto principale
Nvidia Shield Pro Android TV Controller Motherboard Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: passo 1, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: passo 1, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: passo 1, immagine 3 di 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 2, immagine 1 di 1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 3, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 3, immagine 2 di 2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 4, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 5, immagine 1 di 2 Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: passo 6, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: passo 6, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: passo 6, immagine 3 di 3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 7, immagine 1 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 7, immagine 2 di 3 Nvidia Shield Pro Android TV Controller Motherboard Replacement: passo 7, immagine 3 di 3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
  8. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Controller Motherboard: passo 8, immagine 1 di 1
    • After removing the triggers, your motherboard is completely separate and ready to be replaced.
Conclusione
Your motherboard is ready to be replaced.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 499
