Salta al contenuto principale
Nvidia Shield Pro Android TV Controller D-Pad Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, immagine 1 di 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, immagine 2 di 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, immagine 3 di 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 2, immagine 1 di 1
    • Gently open the top frame of the cover with the plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 3, immagine 1 di 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 3, immagine 2 di 2
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 4, immagine 1 di 1
    • Remove the wire attached to the circular piece.
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 5, immagine 1 di 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 5, immagine 2 di 2
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 6, immagine 1 di 1
    • Remove the yellow plug from its socket.
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 7, immagine 1 di 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 7, immagine 2 di 2
    • Remove the two T6 Torx screws.
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 8, immagine 1 di 1
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 9, immagine 1 di 1
    • Gently remove and replace the D-Pad.
Conclusione
Ben Carrasco
Membro da: 01/23/20
347 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G2, White Winter 2020 Membro di Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,923
