Salta al contenuto principale
Nvidia Shield Pro Android TV Bottom Cover Replacement
Cosa ti serve
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 2 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Conclusione
Cal Poly, Team S18-G2, White Winter 2020 Membro di Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membri
14 Guide realizzate
1Commento della guida
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 86
Tutti i Tempi: 2,823
