Salta al contenuto principale
NVIDIA SHIELD Portable Motherboard Replacement
Cosa ti serve
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Replica
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, immagine 1 di 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 3 di 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 3 di 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Conclusione
Altre 3 persone hanno completato questa guida.
Marc Perez
Membro da: 09/29/14
545 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
Un commento
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,802
