Salta al contenuto principale
NVIDIA SHIELD Portable Motherboard Replacement
Cosa ti serve
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, immagine 1 di 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: passo 5, immagine 3 di 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 1 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 2 di 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: passo 6, immagine 3 di 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Conclusione
Altre 3 persone hanno completato questa guida.
Marc Perez
Membro da: 09/29/14
545 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
Un commento
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,813
