Salta al contenuto principale
Nvidia Shield Display Assembly Replacement
Cosa ti serve
  1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Replica
  2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, immagine 1 di 2 Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 3 di 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: passo 6, immagine 1 di 1
    • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
    • Once removed, the display should be able to be detached.
    There is also a screw holding down the ribbon cable to the main board. which needs to be removed prior to display assembly removal.
    Any one know size of screw holding down ribbon cable?
    tgl030 - Replica
Conclusione
Altre 5 persone hanno completato questa guida.
Noel Fletcher
Membro da: 09/22/14
116 Reputazione
1 Guida realizzata
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
Un commento
Where can o get a replacement screen
jorge valenzuela - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,435
