Cosa ti serve
Remove the seven 6.4mm T5 Torx screws from the back panel.
Use the spudger to separate the front and back panels.
Remove the six 6.5mm T5 Torx screws.
Disconnect the power wires.
Peel back the copper tape and disconnect the black and white wires.
Pull the battery apparatus out once all cables are removed.
Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
Lift the fan free after the screws and cable are removed.
On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
Once removed, the display should be able to be detached.
There is also a screw holding down the ribbon cable to the main board. which needs to be removed prior to display assembly removal.
Altre 5 persone hanno completato questa guida.
For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
Any hints at getting the center plastic screw cover out?
Miles Raymond - Replica
