Salta al contenuto principale
Nvidia Shield Display Assembly Replacement
Cosa ti serve
  1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, immagine 1 di 2 Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 1 di 3 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 2 di 3 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, immagine 3 di 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: passo 6, immagine 1 di 1
    • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
    • Once removed, the display should be able to be detached.
Conclusione
Altre 5 persone hanno completato questa guida.
Noel Fletcher
Membro da: 09/22/14
116 Reputazione
1 Guida realizzata
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
1Commento della guida
Where can o get a replacement screen
jorge valenzuela - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,821
