Salta al contenuto principale
Nvidia Shield Controller Buttons Replacement
Cosa ti serve
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, immagine 1 di 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, immagine 2 di 3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: passo 1, immagine 3 di 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, immagine 1 di 2 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: passo 2, immagine 2 di 2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, immagine 1 di 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, immagine 2 di 3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: passo 3, immagine 3 di 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: passo 4, immagine 1 di 1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, immagine 1 di 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, immagine 2 di 3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: passo 5, immagine 3 di 3
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
18 Guide realizzate
2 Commenti
From where can I get the buttons?
Chirag Khatri - Replica
Hey:) I am not sure
Knut Gunnar Walle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 6,091
