Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Unscrew the 7 6.4mm T5 Torx screws from back panel Use spudger to separate front and back panels Use spudger to separate front and back panels
    • Unscrew the 7 6.4mm T5 Torx screws from back panel
    • Use spudger to separate front and back panels
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - Replica
  2. The green grill is not screwed in so it can be pulled right out. The green grill is not screwed in so it can be pulled right out.
    • The green grill is not screwed in so it can be pulled right out.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the 6 6.5mm T5 Torx screws. Remove power wires. Peel back copper tape and remove black and white wires.
    • Remove the 6 6.5mm T5 Torx screws.
    • Remove power wires.
    • Peel back copper tape and remove black and white wires.
  5. Once all cables are removed, pull the battery apparatus out.
    • Once all cables are removed, pull the battery apparatus out.
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew Barbanera
Membro da: 20/09/2014
322 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Hickman Fall 2014 Membro di USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membri
6 Guide realizzate
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,692
