Salta al contenuto principale
Nuvision TM800A510L Headphone Jack Replacement
Cosa ti serve
  1. Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: passo 1, immagine 1 di 2 Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: passo 1, immagine 2 di 2
    • Use a Heat Gun to loosen the adhesive around the inside of the device.
    • Use prying tools to lift the back of the device up.
    • I recommend prying up one side at a time and heating the adhesive to 'just barely too hot to touch'.
  2. Nuvision TM800A510L Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Unscrew the headphone jack from the device.
  3. Nuvision TM800A510L Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Unlock the headphone jack ribbon.
  4. Nuvision TM800A510L Headphone Jack Replacement: passo 4, immagine 1 di 1
    • Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
  5. Nuvision TM800A510L Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Lift headphone jack/ribbon out and it's FREE!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 294
