Salta al contenuto principale
Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement
Cosa ti serve
  1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: passo 1, immagine 2 di 2
    • Unscrew the screws from the base of the blender (These should be 5 gauge phillips head screws).
    • 2 of the screws will be star shaped rather than phillips head.
    • Remove the base plate.
  2. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: passo 2, immagine 1 di 2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: passo 2, immagine 2 di 2
    • Identify the red and black wires topped with white-clear caps.
    • Use pliers to squeeze the flattened part of both caps.
    • The black and red wires attached to the power cord should be loose and ready to pull out.
  3. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: passo 3, immagine 1 di 1
    • Replace the cord by slipping the new cord's black and red wires into the caps.
    • Pinch the middle of the cap back to the flattened position using the pliers.
Conclusione
Allie Decker
Membro da: 09/26/17
125 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G1, Banghart Fall 2017 Membro di Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,935
