Salta al contenuto principale
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: passo 1, immagine 1 di 1
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: passo 2, immagine 1 di 1
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: passo 3, immagine 1 di 1
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: passo 4, immagine 1 di 1
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: passo 5, immagine 1 di 1
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: passo 6, immagine 1 di 2 Numark TT1600 Belt Drive Replacement: passo 6, immagine 2 di 2
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: passo 7, immagine 1 di 1
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Nikolai
Membro da: 10/12/11
254 Reputazione
5 Guide realizzate
Cal Poly, Team 17-14, Regan Fall 2011 Membro di Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,384
