Salta al contenuto principale
Numark N4 PCB Circuit Board Replacement
Cosa ti serve
  1. Numark N4 PCB Circuit Board Replacement, Numark N4 Disassembly: passo 1, immagine 1 di 1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 PCB Circuit Board Replacement: passo 2, immagine 1 di 1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 PCB Circuit Board Replacement: passo 3, immagine 1 di 1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 PCB Circuit Board Replacement: passo 4, immagine 1 di 1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 PCB Circuit Board Replacement: passo 5, immagine 1 di 1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 PCB Circuit Board Replacement: passo 6, immagine 1 di 1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 PCB Circuit Board Replacement, PCB Circuit Board: passo 7, immagine 1 di 1
    • Locate the top right PCB circuit board.
  8. Numark N4 PCB Circuit Board Replacement: passo 8, immagine 1 di 1
    • Unplug the two ribbon cables as shown.
  9. Numark N4 PCB Circuit Board Replacement: passo 9, immagine 1 di 1
    • Loosen and remove the 11 12mm screws from the circuit board using a Phillips #2 screwdriver.
  10. Numark N4 PCB Circuit Board Replacement: passo 10, immagine 1 di 1
    • Carefully remove the circuit board from its housing.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro di USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,381
