Salta al contenuto principale
Introduzione
This method of opening your Numark N4 only requires removing screws and prepares it for the repair guides featured here.
Parti
Nessuna parte specificata.
  1. Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  4. Using your fingers, gently unplug the larger ribbon cable as pictured.
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  5. Using your fingers, gently unplug the smaller ribbon cable as pictured.
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  6. Using your fingers, gently unplug the yellow and red cable as pictured.
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  7. Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
Conclusione
Hunter Bassett
Membro da: 10/10/2017
104 Reputazione
1 Guida realizzata
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro di USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 36
