Salta al contenuto principale
Introduzione
This guide shows how to replace the audio jack without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Parti
Nessuna parte specificata.
  1. Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Using your fingers, gently unplug the larger ribbon cable as pictured.
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  5. Using your fingers, gently unplug the smaller ribbon cable as pictured.
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  6. Using your fingers, gently unplug the yellow and red cable as pictured.
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  7. Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  8. Turn the panel around so that the audio jack is facing forward as shown.
    • Turn the panel around so that the audio jack is facing forward as shown.
  9. Using a soldering station, carefully desolder the connection points around the audio jack and remove it.
Conclusione
Erik Charlton
Membro da: 10/10/2017
600 Reputazione
5 Guide realizzate
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro di USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 136
