Introduzione
Most of your time will be getting the back off of the device. The cameras are held down with a little adhesive but are relatively easy to remove.
Cosa ti serve
Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
Use thin tools to pry the back of the device off.
Be advised that you will need to replace the adhesive.
