Salta al contenuto principale
NuVision TM1088 Motherboard Replacement
Cosa ti serve
  1. NuVision TM1088 Motherboard Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
  2. NuVision TM1088 Motherboard Replacement, Motherboard: passo 2, immagine 1 di 1
    • Remove the two plugs for the screen by pulling up and away from the motherboard.
  3. NuVision TM1088 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
  4. NuVision TM1088 Motherboard Replacement: passo 4, immagine 1 di 1
    • Melt solder and remove red and black wires leading to the battery.
  5. NuVision TM1088 Motherboard Replacement: passo 5, immagine 1 di 1
    • Melt the solder on the black and gray wires and remove wires from motherboard.
  6. NuVision TM1088 Motherboard Replacement: passo 6, immagine 1 di 1
    • Melt the solder and remove the red and black wires leading to the speaker.
  7. NuVision TM1088 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the four 4 mm Phillips head screws holding in the motherboard.
  8. NuVision TM1088 Motherboard Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard away from the front cover assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,678
