Salta al contenuto principale
Novatel MiFi 2200 Case Replacement
Cosa ti serve
  1. Novatel MiFi 2200 Case Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: passo 2, immagine 1 di 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: passo 3, immagine 1 di 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: passo 4, immagine 1 di 1
    • Once the seal has been broken all the way around, open the cases using your hands.
Conclusione
Altre 2 persone hanno completato questa guida.
Justin Russo
Membro da: 04/15/12
196 Reputazione
3 Guide realizzate
Cal Poly, Team 7-36, Maness Spring 2012 Membro di Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membri
5 Guide realizzate
Un commento
If case gets damaged, is there a place to but the case
Snehraj Merchant - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,555
