Salta al contenuto principale
Novatel MiFi 2200 Battery Replacement
Cosa ti serve
  1. Novatel MiFi 2200 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Battery Replacement: passo 2, immagine 1 di 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Battery Replacement: passo 3, immagine 1 di 1
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  4. Novatel MiFi 2200 Battery Replacement: passo 4, immagine 1 di 2 Novatel MiFi 2200 Battery Replacement: passo 4, immagine 2 di 2
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
Conclusione
Charge your new battery and you are ready to use your Mifi again.
Carissah
Membro da: 04/15/12
147 Reputazione
2 Guide realizzate
Cal Poly, Team 7-36, Maness Spring 2012 Membro di Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,049
